jeff33 »
https://forums.nicoclub.com/jeff33-u52768.html
Wed Dec 27, 2006 9:11 am
Thanks for removing the duplicate posts.
ALso, thanks to all of those following this post and providing input.
Here is what i have done.
I ran the transmission self-diagnosis without consult. The diagnositic information display never changed from "AT CHECK" which informed me that the damaged circuit is "inhibitor switch, 1 range switch, kickdown switch, idle switch or diagnostic information display system circuit is disconnected, or A/T control unit is damaged."
Per the instuctions, I am to "Go to inhibitor switch, 1 range switch, kickdown switch, idle switch or diagnostic information display system circuit checks."
I ran the checks and found the following:
(1) the inhibitor switch circuit is OK (checked voltages of terminals 16-20 for various shifter positions).
(2) the 1 range switch circuit is OK (checked voltage of terminal 39).
(3) the kickdown switch circuit is OK (checked voltage change of terminal 41 with depressing/releasing of pedal).
(4) the idle switch circuit is N.G. (no voltage change for terminal 14 when changing pedal position).
Based on test #4 being N.G., the flow chart directs me to "Perform self-diagnosis (Mode IV) for engine control. Check idle switch circuit."
THis is where i am stuck - i don't know what Mode IV is or where to find it. Perhaps it is a typo (i have found numerous ones over the years).
So, if someone can direct me as to how i can check the "idle switch circuit" I would be very grateful.
I am excited that this is where the self-diagnosis is heading because I am having serious high idle problems that occured at the same time as the transmission malfunction (during the injector change).
Thanks for your help.
