SixGuns »
https://forums.nicoclub.com/sixguns-u95290.html
Mon Sep 07, 2009 10:14 am
Kinda true, so if you don't know how to change the oil, take it to Jiffy Lube or Wal Mart, but against my better judgement....to get to the oil filter, there's a plastic skid plate which is pretty much just a plastic barrier to keep crap out of the bottom of the engine, which works about as well as tits on a boar. 6 little bolts (10mm, if I remember correctly), and it falls on your face, along with years of dirt and crap. You can see and change the oil filter. Put it back on when you're done, don't lose the bolts. It's pretty much worthless, so if you intend to do any offroading, get the solid steel one off of 4x4parts.com. I've bashed the hell out of mine and broken big rocks into little ones and only managed to chip some paint off of that beast. Makes oil changes a PITA, though.
