Where is my TCU?????
Project_S13_180
Car: ya know
i need to replace my TCU, i know its by my drivers side kick panel and its a white box...but where is it? i see one white box behind my kick panel and thats for my door chime...where is that thing at? my gauge lights dont work, there is another s13 im getting a TCU from but i cant get it til i figure out what it looks like...so somebody send me a pic or describe in great detail for me, thanks
0range_240
Car: 89 HCR32
is that a STICKER of an intercooler on the front???!
Kiwi_S13
Take the kick panel off and it is plainly visible - a small white box about 2x2x1 with one small harness running in. It is only held on with one bolt/screw if i remember correctly. And the appropriate term is TCM.
L0sT
this is what it should look like...sorry if its small, its from my phone
copy n paste into a new window if u cant click it
Project_S13_180
Car: ya know
sticker of a intercooler?????? elaborate for me :-D
Project_S13_180
Car: ya know
the picture wont show up for me :-(
L0sT
Project_S13_180
Car: ya know
thanks, i just got a TCM and my lights work!!! its SICK! thanks for the help
L0sT
that is it though..right? cuz i gota change mine too lol
Project_S13_180
Car: ya know
yeah thats it, only takes about 5 minutes to change out the old and put the new one in..probly not even that
L0sT
damit, i got one from a 93 240 and it still dont work...do u have a analog or digital/hud cluster?
Kiwi_S13
Lost - Have you installed a new stereo lately? Did it blow when you did (if you did).. If this is the case you need to REWIRE your system to bypass the factory amps.
EDIT - Or the new one could be blown.. This seems like a very common problem lately. Open the TCM up and check it visully for burns on the circut board. They should be quite obvious.
L0sT
nope, the new TCM looks fine, no burn marks or anything...so a new deck can blow the TCM? how do i rewire it to bypass the amps?
Kiwi_S13
I don't remember exactly. I know the illumination wire should NOT be hooked up, and I think you need to have the power antenna wire and amp wire come together... Search though it has been a long time and I dont remember completely. Good luck.
Post Script - Lost you might need another tcm. The second could have blown too.
swtslvrmonkey
Car: 1981 Datsun 310 Gx
hey guys, same thing happened to me, i have a 90 240sx, and when ig ot it it had no dash lights, so i figured either the light bulbs burned out or there was a short in the wire, but obviously not, since i removed the whole gauge cluster, and so i came upon this thread and read abotu the TCM circuit board, and i decided to give it a shot and took it out, and certainyl enough i foudn out one of the circuit boards was burned, so i was fortunate to find the problem, until yesterday when i bought another TCM from my local junkyard. I checked to see if there was any circuit lines burned out, and no. I put it in, connected it and plugged my battery and everything. As soon as i turned ont he switch, bam i start smellin smoke, and i took out the TCM again, and sure enough the same exact circuit line that burned out ont he other one, it happened to this one as well. I have a stereo hooked up as well, but im not too sure how the whole stereo wiring goes and how it affects all my dashboard lights, (i sortof need a visual wiring diagram of some sort since im a newbee at this) ALl of my other lights work, pretty much everything, jsut the dashboard and everything is not lighitng up. I know for a fact the reason why my tachometer aint workin. Do u think its because of the SR20DET engine i got there that could be the problem? let me knwo guys, i would appreciate it, sorry bout the mispells. thanks
swtslvrmonkey
o and i need to change my tachometer gauge to that of a newer 240, sorry i made it sound like i dont knwo what to do with my non-workin tachometer, my main problem is those darn dashboard lights.
IveBeenBad
Car: 1990 Nissan 240SX Fastback STOCK BIOTCH
anyone know how much one of these is from a dealer?
Kiwi_S13
Ive seen/heard anywhere between $150 - $300.
Junkyard = ~$10
swtslvrmonkey
mine was for free ^-^
alex7542
Car: Racing and high horsepower
Whats tcu??
alex7542
IS it throttle control unit
Kiwi_S13
tcu - transmission control unit TCM - timing control module (which is what this thread is about)
alex7542
Could the tcm cause no spark. if it does back?
alex7542
my bad i meant break
Kiwi_S13
No.. Check your car for codes - and start a new thread.
alex7542
ok. thanks. To check for codes i take the ecu off and read the lights right.
black240sx93
Car: 1993 240sx se hatchback
I was woundering if any one knows if the TCM can make the gauge cluster not to work.
sdtouge
Car: 1990 240sx coupe
if you have s13 with h.u.d they just dont work anymore. i tihnk there are like 3 people in the world that have theirs still working.
if you want a spedo get a turbo timer...
black240sx93
Don't have hud.I have a 1993 s13 Hatchback.
sdtouge
ok. have no clue then,,,
