I circled three possible positions with the red line. Are they right? Thanks a lot.DAEDALUS wrote:Leave the plenum alone. The plugs are under the coils--the black things with 2 bolts each and a harness to each. Remove the coils and the plugs are right there. The slight mods they made for the J make it way easier to get to all of them than on the Z.
Just *PULL* the coil? I am a little afraid of using rude force . (The first step to DIY is a challenge to me. :P)IvoryJ30t wrote:those are the coil packs. remove the wiring harness, remove the two bolts, and pull the coil out. the spark plug will be underneath.
Indeed.. I used the twist and pull method.. Sometimes theyre kinda stuck on there...boris_hu wrote:Just *PULL* the coil? I am a little afraid of using rude force . (The first step to DIY is a challenge to me. :P)
Thanks a lot.
-boris
