Well I don't expect it to be perfect, just the way it was before when I first got it... I could go that first 3,000 miles after a change and never have to add a drop no matter how hard I rode it. Only after that would it loose some oil slowly till I changed it again. Drifting occasionally every day for over a year back then. Then I got in a pinch financially and couldn't afford to keep buying tires and just drove it normal for the past two years with occasional slide sesssions and hard pulls but not regularly at all Like maybe once a week. Trying to be conservative mostly. It started getting in a state of disrepair due to my not having money to properly diagnos it and upkeep it. That's when the leak got bad. Now I'm on it the same as I was when I first got it and it's going through oil very fast compaired to what it was when it was new to me that first year.OM3GA wrote:Mine may have been burning oil slightly or it was blowby and then it was burning it that way. Either way i ran 10w30 Royal purple in my KA and after hard drives typically every 3 or 4 days i would add about 200-300 ML of oil.
Not really a big deal, imo its normal for older motors to use a small amount of oil on a large amount of abuse. I wouldn't get too worked up about it, just make sure you check your oil once a week or so and add accordingly. You really can't expect to just change your oil and not have to touch it again until the next change do you?
My car did not smoke at all either. It definitely was not leaking because every gasket and seal was brand new and confirmed dry.
Just my opinion but that seems normal to me.
lol I like the hypie excuse better... hahakouki munster wrote:There is a tiny portal to another dimension full of tree hugging hippies in your oil pan, you should be happy about that, because of you hippies will get cancer and die. But seriously its being burned off, its not something to get up set over, your ka has 200,000+ miles on it and based on your description it has been beat on pretty hard. Just run a less expensive synthetic oil and keep a close watch on the oil level.
Also, it won't smoke enough to be easily seen unless the valve stem seals or a rings are pretty worn out.
Is that something to worry about?? Like does that mean my engine is on it's last leg and I should be saving up for a rebuild soon or will it just do this and not have any problems cause of it from now on?? Blow by really worries me...OutToWinPAHC wrote:200K yeah past you rings or down the valve stems
Will do. Valve stem seals make sense though as my car ran really lean and had a high amount of knock (reading from sensor) for almost two years untill I finally figured out I needed to replace my fuel pump. Just to give an idea... now the highest knock reading I get is 9 after I've been driving hard on the interstate and doing high throttle runs constantly for about thirty minutes. When the fuel pump was bad (installing the AFC and AF gauge is how I finally figured out it was the fuel pump btw) I was going all the way to a reading of 250. Idk but that just seems crazy bad like IDK how the engine still runs after that. It was flooding at idle and then going so lean at throttle that it would litterally not read on the 02 sensor. I chased that grimlin for years before I finally figured it out. The guy at the local nissan tuning shop hooked it up to nissan consult and said it was off the charts lean beyond 125% and he had no clue how I drove it their....OutToWinPAHC wrote:This is what you do.
Check compression dry, if number low do the test with some oil in the cylinder and see if the rings are blowing oil past. Read how to compression test, and west compression test.
If you pass compression test, then check for external leaks, internal leaks (hard to do with good compression), and replace the valve stem seals. If it not intermixing, and not getting pass the rings your burning it somehow, most likey from above (valve stem seals)
