Checking out under the plenum with a flashlight, I don't see any puddles of coolant. Actually, tonight I don't see any coolant dripping down the front of the oil pan either. What I see is a frayed hose towards the 3 o'clock position on the plenum right near the throttle cable. The hose faces down and then kinks 90 degrees under the plenum on the backside.maxnix wrote:Can you say under plenum job?
Your efforts to not dangle a partciple are commendable.
So will the hoses I receive in the under plenum hose kit from Joe most likely fix the leak? Coolant will serve me much better by NOT being in a puddle under my car.
I prefer my participles to be thoroughly kept in check. Ain't nothing wrong with writin' good.
P.S. Is there a NICOclub discount on infinitipartsusa?
Hell, do it now. Catastrophic coolant failures are fatal to the VH45DE and the heat gauge will let you know about 3 minutes after your engine is cooked. Just not worth fooling with it.Q45denver wrote:Better to Get-R-done before summer.
I'm pretty sure the filler neck was replaced on my Q by the previous owner. I'm looking to take care of this problem this week coming up.Q45denver wrote:Another thing you might check is the radiator cap as they can leak after a few years. I know on my 1990, I also had to replace the filler neck with a redesigned one as it kept leaking.
No real NICO discount but you can get 25% off by talking to Joe or ordering over the internet and sometimes they have specials. I think they sell a hose kit as well as a plenum kit? Better to Get-R-done before summer.
The updated design is cast aluminum... the old one is a flimsy brass. Good to know, because you only need a replacement cap if the neck has been replaced already.DoinkMobb wrote:I'm pretty sure the filler neck was replaced on my Q by the previous owner.
