slickroger wrote:That might not be true
you have a 2001 Qx4, I believe your front doors have amps in them.i have an 01 pathfinder and the two front doors have there own amp in them for that door speaker and the pillar tweeter. you might want to make sure.
Thanks Roger, I'm getting some hissing out of a new nav head unit that was put in and I figured that the signal was processing through and amp in the fronts. But my repair service manual doens't say anything about a front speaker amp. I have new JL Audio components setup in the front but the guy that wired them was was super super lazy and did a really crappy job. I don't know if he bypassed the amp(if there is one) or not. I doubt he did and I'm figuring that this is the root of my problem. Can you explain exactly where the amps are located?
I was able to disconnect(easier than removing) the rear speaker amp which was really simple. Now I just have to rewire my entire car, yay!
Billy
