where is junction for ignition
goixiz
Car: Cycling and cars
I know this is a simple thing for all of you but call me slow. Any help is greatly appreciated
Ive got the turbo timer and the harness adaptorNOwWhere do i find the harness under the steering to splice it toand what parts do i have to remove to get to it ?ANy pics is again a great help
thanks in advance
psI also need a quick description on the parking break connection
MojoMan
Car: working on cars and women
there are six plugs that go to your steering column and this does depend on which model you have but the six is for the se with fogs lamps etc. These plugs come from the SMJ-super multiple junction which is on the driver side above the fuse box. Is yours an s13 or s14? The discription Im giving is for the s-14 but is real similar to the s-13. It should be a thin four wire plug with a three row look to it. Someone correct me if Im wrong but it should be correct. As far as the e brake swith goes it goes under the seat and under the center console. You should be able to get to it under the console if you take it up a little. Iv'e only taken up the center console once and that was for my NOS along time ago so I cant quite remember what was the easiest way to get to it. I hope this helps a little.
