Where is it?!?!
TDot
Car: 2008 M35X, Lakeshore Slate/Tan
I'm feeling super slow right now! How do I use this CD changer? I've never had an issue like this before with audio equipment. This car is suppose to come standard with an in dash 6 disc player, the manual says something about needing to press a load button, I see no load button, I looked at numerous other 08 m35 for sale with "6 disc changer" and none of them have load buttons. So where and how do I load 6 discs? The manual seems to be leading me down the wrong direction, and when I press the 6 buttons they don't seem to do anything or give me any indication.
The00Dustin
Car: 2006 Infiniti M45
I was going to reply to tell you it's to the left of the CD slot, but I just looked up a 2008 M35 on eBay and it didn't have a load button, so I looked up a 2006, and sure enough, it's to the left of the CD slot. Have you tried the eject button? Maybe you press it and then a number for an empty slot or hold it when the slots are all empty (sounds lame, but who knows). Does the manual not have a picture?
TDot
I thought about the eject button, button pressing that while the thing is playing a cd just causes that cd to eject.
mazz
Car: 2013 M37x Advance, Tech Touring and Premium, Black with Stone Interior
my 2006 had a 6 disc changer my 2008 has only a single disc player and hard drive music
i sure dont know if they are all like that but just slip the disc in no load button needed on my 2008
Logan00
Car: 2008 Black M35x
TDot wrote:I'm feeling super slow right now! How do I use this CD changer? I've never had an issue like this before with audio equipment. This car is suppose to come standard with an in dash 6 disc player, the manual says something about needing to press a load button, I see no load button, I looked at numerous other 08 m35 for sale with "6 disc changer" and none of them have load buttons. So where and how do I load 6 discs? The manual seems to be leading me down the wrong direction, and when I press the 6 buttons they don't seem to do anything or give me any indication.
Does your car have the tech, advanced tech or premium package? If so, you don't have a 6 disk changer, you have a hard drive music box system where the disks you play are recorded to the music box system.
Click the "Aux" button and go through the different choices and if you see "Music Box" then there you go. I initially ran into the same thing as you when I got my car but after reading a litle more online I learned that the cd changer is not included if you have the music box system, which would explain you not having a "load" button.
Good luck
