Where is Fuel Pump on 09 Versa HB ?
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
conversation
Car: Versa 1.8 S HB
Hi,
Where is the fuel pump on the 09 V Hatchback ? I just spent 20 minutes searching, searching, searching for it on the net. Nothing.
I read here that it is possibly under the back seat. Does that mean it is INSIDE the car, and that you can remove the back seat and look at it and touch it ?
Surprised they would allow any gas inside the passenger area for safety reasons.
Maybe it is underneath the car, beneath the back seat ? I didn't see a fuel pump when I looked under the car.
Thanks
blindsnyper
Car: 2007 versa
i believe you have to remove the back seat. maybe there is a cover plate to keep it outside the cabin???
Versa357
Car: 2009 Nissan Versa 1.6 Sedan
conversation wrote: Surprised they would allow any gas inside the passenger area for safety reasons.
Thanks
The only part that is in the car is the top of the pump where the wires are. No gas is acually pumped into the passenger cabin.
ryankyorei
Car: Latio sport
any idea what's the capacity of the pump?
soros151
Car: Nissan Versa 09 Hatchback / Toyota Camry 95 Coupe
ryankyorei wrote:any idea what's the capacity of the pump?
Why do you have a Turbo Timer?...emm If you don't have turbo on your car? Look at your mod list.
NODES
Car: 2007 Nissan Versa SL (Blue)
He may, there use to be a Turbo model around the forums
ryankyorei
Car: Latio sport
hi,
infact the mod list is my previous setup..now running on force induction...
i have posted some qn in other thread saying i have already force induct my ride..
so anyone knows the pump capacity?
cheers
ryankyorei
Car: Latio sport
no ones has a clue on the pumping rate for the fuel pump?
NODES
ryankyorei wrote:no ones has a clue on the pumping rate for the fuel pump?
I do not even think a dealer or technician would know.
alonsorules8
Car: 2008 Nissan Versa SL HB
the service manual has no specs for the fuel pump rate of flow. The only way to check that would be with a Consult II obd reader. That would be my guess.
Modified by alonsorules8 at 8:29 PM 11/9/2009
Return to “Versa Technical Discussions”
