Where/how should I mount my satellite radio...
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
cdwillie76
I have a portable Sirius radio that I need to mount inside my Versa. I am looking for ideas for others that might have done so already. In my old Altima, I have a nice metal mount that attached on the posts to the radio. I might be able to do the same thing with the Versa but it seems like it would cover up to much of the radio. Any suggestions would be great.
ThanksChris
arco
I bought a cup holder mount for mine. Takes up one of the front cupholders (the right side one) directly below the console, but I never used it anyway. Works great for me. It's also close enough to the passenger seat floor mats, which I use to hide the antenna wire.
equlizer
Car: Nissan Versa SL with SVT transmission
if its small enough, it could fit in the little cubby above the stereo head unit. I got my ScangaugeII in there and fits snug. So i guess if its that size, your ok
hrdcorpdrummer15
Car: 2008 Nissan Versa
I mounted mine under the a/c control panel, just behind the shift knob. its clean and doesnt get in the way. ran the wires along the sidewall of the passenger side and down under it, under the rear seats and to the back for the antenna
imac_89
I have a SIRIUS Plug&Play Radio in my Versa & I use the vent clip. I have it mounted on the driver side vent of the radio. This also allowed me to run all then wires down by the steering column plastics to whereever I needed! I seriously think it was a clean install.
JakMaehoffer
I placed mine in the lower middle of the windshield using the suction cup mount. I took out the lever that controlled the middle upper vents and ran the wires through there.
Return to “Versa Technical Discussions”
