SteveTheTech wrote:Looking good Jeff I'm glad to see your still kicking. Jeep looks like it's coming along. I personally like the air hole in the firewall.
My 327 crank pulley rests over the front axle so I guess you could say its "mid" engined??
I didn't want the Jeep to wander at speed.
The hole in the firewall is for stoplight racing timing adjustments :-) Just stick your hand under the dash and turn for an extra 25 hp.
I spent $7,000 in 2001 on building the 327 it is full roller. Should make around about 400-450 hp and have good low range torque.
The gears are 4.56 front and rear, the transmission is a rebuilt Chevy truck SM420 with a 7:1 granny first and my Spicer 18 transfer case has a 2.8:1 low range. I should be able to climb anything.
My garage is a 3 car with a tandem 2nd half. I saw the garage and knew I had found our house. I had the builder run extra dedicated outlets including a single 240 volt 50amp on its own line. I also had the garage pre-plumbed for a sink that I never put in.
