Where does this hose connect??
tonis56
Car: 04 Titan Crewcab
Im mocking up my intake manifold before I put everything back together. I just cant figure out where this hose connects.
This picture shows the bottom of the intake manifold and where I thought that it might go, (out lined in red) but think the hose in this picture is installed correctly. Correct me if im wrong
tonis56
To the top
HardcorePS13
I believe that is one of the throttle body coolant hoses.
tonis56
this hose goes to the rear end of the engine. I have the other TB hoses connected.
tony-
tonis56
TTT
HardcorePS13
There is a line that runs to the IACV, that might be your best bet.
tonis56
The second picture is of the IACV and both of those hoses seem to go there. Even if I swap the existing hose with one of the ones in the second picture, I will still have an extra hose.
tony-
tonis56
Bump it TTT
Nismo_Freak
Car: 89 Nissan 240SX
How about you give pictures of where the rest of your hoses are going.
I swear that hose looks just like the one that goes to the throttle body.
Notice it's origin and the fact that it has the same protective boot. Spin that hose around and I bet it goes to the throttle body.
tonis56
I can check the TB again. Ill get back to you about this.
DarkBlueSr240
I disconnected the coolant lines that go to the throttle body and connected them togeather I looked at it as a anti intercooler
sr_powered
Car: 1990 Nissan 240sx SE
check your steering or brake master cylinder? theres a hose coming from there to the intake manifold side of the engine. i think thats where it should go if im correct.
tonis56
sr_powered wrote:check your steering or brake master cylinder? theres a hose coming from there to the intake manifold side of the engine. i think thats where it should go if im correct.
yea i already have that hose taken care of.
DarkBlueSr240
isn't that for the clutch..
tonis56
no, this is a coolant line of some sort.
