where does this go?
bRadical
Car: maroon 95 240 RB inside (Eatn By The Dragon)
black 95 240 RB25inside (running by 11-18-10)
all but ready to start my rb25 but im not sure where this plug goes 95 s14
its under/behind the glove box
thanks!
Cidate
Car: 95 S14, gutted, caged, sr. Track car/Daily driver :X
that connects back to the the harness near the ecu right? looks like it was wired for a s13.... should be for your dash plug!
bRadical
so essentially it plugs into the main harness? if so then how do i rewire it all because theres 2 male plugs one on the main harness and the one pictured. im assuming they are supposed to be plug and play and its not.
Cidate
pictures might help. get those up and ill prob be able to give you some more general info to get you on the right path :D
johnny butt
Car: 1993 240sx Convertible
I didn't use it.
You won't use the other one already attached to the body harness either.
BTW, Someone else needs to chime in here, as I'm running an S13, so I can't really speak for the S14. I wouldn't imagine it would be any different though.
bRadical
well if it doesnt hook up my next issue is im not hearing the fuel pump come on when i turn the key. gunna check for a light on the ecu in the morning i suppose... any help would be appreciated!
gmac708
Car: :o)
1970 Datsun 240Z
1972 Datsun 510
Here is a shot of 1996...I think this is your connector. It goes on the blower motor.
Hope that helps
Gord
bRadical
thanks gmac! heres some more pictures dont know whats goin on no fuel pump or anything goin on when i turn the key.
i was thinking the 2 brown plugs were to hook together lol! any ideas other than not gettin power to the ecu as to why nothing is working? stereo turns on, windows go down, but when i turn the key to prime the fuel lines i dont hear the pump kick on...
