black g50 wrote:My q has a red rubber tube hanging off filler neck,that looks like a drain tube,but I dont see where it drains from body to outside.Its not attached to anything else. There also are two clear plastic hoses joined together that are fitted into a hole in quarter panel,but have no idea where to plug red hose into.Have to check again,as I think I dont have a metal line like that drain tube on car.
I went outside and poured about 2 tablespoons of jet fuel (since it has a low flash point) down the little hole. It disappeared down the line that runs down the rear fender well. I wanted to see if the fuel would drip out of the car. No drips could be found. The position of the drain allows both fuel from an overfill and water from a wash or hard rain to run down that hole and exit via that line..
I checked the FSM on page EC 7 and that line is not in the diagram. So I"m stumped on this one.
