Where does the negative battery cable bolt to on a 92'?
prdquik
Car: S13
Just got done changing out my motor that had a cracked head, but can't find where the negative battery cable bolted to. Does it bolt to the chassis in a specific spot or does it bolt to the block in a specific spot or what? Thanks.
AZ89two4Tsx
The frame I think.
Lol I can't remember and I just changed my terminals a few weeks ago.
yangs13
Car: 1993 240sx-Dead, 2001 Maxima
strut tower area passenger side, kinda close to the overflow tank. should be a hole there.
MastaYu
Car: 92 Nissan 240SX SE HB
The ground from the battery goes to the intake manifold.
prdquik
Car: S13
Seems like the answers are mixed. Anyone have a definitive answer?
prdquik
Car: S13
MastaYu wrote:The ground from the battery goes to the intake manifold.
the negative battery cable? It just bolts straight to the intake?
Wc240
Car: 89 Nissan 240SX
97 Nissan 200SX
91 Nissan 240SX ka-t
06 Scion xB
2000 Nissan Frontier
it bolts to the manifold and the body. look in the FSM, it'll show you exactly where it is
prdquik
Car: S13
Wc240 wrote:it bolts to the manifold and the body. look in the FSM, it'll show you exactly where it is
I looked all through the my FSM and couldn't find it. Its the negative battery cable and it comes down and is held on to the battery tray, then it comes done more and I don't know where it goes from there. Could someone check their car for me it will be greatly appreciated.
Driftlife!
Car: SR20det powered 91 240sx.... vvvrooooooooom.. psshhhh!
prdquik wrote:I looked all through the my FSM and couldn't find it. Its the negative battery cable and it comes down and is held on to the battery tray, then it comes done more and I don't know where it goes from there. Could someone check their car for me it will be greatly appreciated.
i have my battery located in the rear. my negative is connected to the strut tower on the inside of the car .. like yangs13 said there should be a hole there.
the intake manifold is also a good place too. but me personally i prefer the body.i recomend a nismo ground kit. makes your car happy.!
Firewind
Car: 240SX
So officially in the S13, the negative battery cable connects to 2 spots. The first spot coming from the battery is at the base of the battery tray. This grounds the body of the car. The rest of the cable connects to the bottom curve of the intake manifold. It's bolt hole is right next under where the throttle body cable hooks onto, can't miss it. Bolt hole, flat spot, yeah, right there. Hope that helps!
