There are two looms at the same split, one is a jumper bank (dead end) taped to the main loom. The second is the 9-pin connector that you are looking for. On the factory harness there is not the smaller "quick connect" white connector in the middle, the loom ends in the large 9-pin plug which then runs to the body loom. Wiring specialties added the "quick connect" because the factory 9-pin is a huge PITA to get through the firewall without removing the blower, evaporator and ducting along with the dog leg clip that's down there.
Anyway, what are you trying to do?
