evildky »
https://forums.nicoclub.com/evildky-u13100.html
Mon Feb 23, 2015 9:37 am
Must be a manifold or engine from a 79 or later. your 78 should have an "N42" block, the 81 switched to "F54" the block ID is cast into the engine just behind the drivers side engine mount. Might want to check your head as well, it's located on the passenger side near the base of the head between #1 and #2 spark plugs. Your 78 should be N47 (correct head not a great one), 79-83 na is cast P79, (an even worse head).
