DjPantsSpecR »
https://forums.nicoclub.com/djpantsspecr-u24575.html
Thu Oct 13, 2005 5:35 pm
yep.
to get this done you have to weld a plenum around the air horns of the ITBs, and run a standard intake pipe, or ram if you will, to the MAF and the air filter
however, i gotta add using a megasquirt ecu and converting to a MAP sensor is the way to go here, as adding a plenum and a ram will cause some effects that may be undesired if you dont know how to control them
