where do these two plugs go?
getnrowdy23
Car: '95 sr20det 240sx se/2004 suzuki sv650s
just need to know where these two plugs go? they are in the passenger side of my engine bay in the back by the firewall. motor is an s13 blacktop sr 5speed in a 95 240sx. thanks a lot
getnrowdy23
another pic
getnrowdy23
one last pic of that wire
getnrowdy23
here is the other wire, this one has a ground with it...
getnrowdy23
thanks for the help guys
robbbby
WTF how do you look at pictures. They never show up in posts for me and when I click them I get
File attachments can only be linked from the message board server; Outside linking is not allowed.
Your referrer: http://www.nissaninfiniticlub....91511
getnrowdy23
do one of these go to this? this is against the firewall on the passenger side... if it does go there, which plug is it?
Onizuka
Car: 91 Nissan S13 coupe SR20DET
89 Nissan S14 hatch SR20DE
Could be an automatic transmission harness, cant find them on my harness. but then again, i dont have a flashlight and its dark and rainy out. I try again later when I get back from class.
robbbby
Ok, how are you seeing these pictures, someone want to fill me in.
getnrowdy23
it should just pop up when you browse the page, check you settings. go to tools/internet options/ advanced tab/ show picture (under multimedia)try that
SpeedRacer1
Car: 1990 240SX, G35
My initial guess without research would be Wiper motor, and ABS. If you dont have ABS then chances are it wasnt plugged in before.
getnrowdy23
true.... i dont have abs... i will look into that and see if that is what it is, unless someone knows for sure before i get back home. thanks
getnrowdy23
jspec, it is a auto harness (tps has 6 wires)
proimport17
Car: motocross, baseball
The second one is definetely wiper motor and i believe the first one is abs
s13sr20chris
the thing in the box is the wiper motor i agree that is one of the connectors(boxy one). the gray connector looks like it goes to the injector or ignition subharness. check that.
getnrowdy23
i will check everything you guys have said when i get back into town on sunday. any other ideas? or would better pics help or anything like that?
getnrowdy23
could that first plug go into the amplifier?
VitaminT
Car: 93 240sx SE
I agree that the first plug goes to the ignition subharness (coilpacks) and the second one goes to the wiper motor on the firewall.
nismofly
Car: 89 Nissan 240SX Hatch
robbbby wrote:Ok, how are you seeing these pictures, someone want to fill me in.
your on the nissaninfiniticlub.net server, go to http://www.nicoclub.com/
getnrowdy23
VitaminT wrote:I agree that the first plug goes to the ignition subharness (coilpacks) and the second one goes to the wiper motor on the firewall.
do you have a pic that can show me where about these two things go?
proimport17
Dude this is a really old thread. Hopefully he has figured it out by now.
getnrowdy23
well not really the wiper one i havent figured out the wipers work... just not the first level down on the wiper switch. the medium and high work tho. but when i turn the wipers off it stops wherever the blades are (it doesnt automatically go back to the bottom of windshield) thus i asked where the wiper plug goes =)
