Where do these hoses go?
Two-Fortee
Car: 180sx.
right by my air filter on my 180 there is a small canister, with 3 hoses coming out of it. 1 is a hard rubber line which I think runs to my gas tank, but I can't figure out the other 2. Do they go to my intake mani and run as a vac line? One of the nipples on the tank is slightly larger than the others. Thanks.
Cams
Car: 1993 Nissan 200sx CA18(DET) RS13
2002 Mitsubishi Airtrek JDM 4G63T (wife)
2013 Scion FR-S
2016 Infiniti QX50
crap, can't find the article at SXOC where they tell to bypass the entire unit.
You can simply unplug all the lines from it, cap the one on the intake piping, and run the vacuum line coming from the intake manifold directly towards your fuel pressure regulator.
Let me keep looking for that info.
Cams
2013 Scion FR-S
2016 Infiniti QX50
Here is some info on it. Others can add more comments. I bypassed it entirely.
http://www.sxoc.com/vbb/showthread.php?t=122706
Good luck.
r34 gtr
95.5 Audi URS6 Avant 5spd
03 BMW 330i ZHP 6spd
89 Nissan 240SX base CA18DET
I took mine out and hurled it into the sun. Make sure you don't plug the line that goes to the tank though, as you will build up a dangerous amount of pressure in there if it is plugged. I just got a little bit of hose and re-routed it down by the frame rail.
