Where do these 2 hoses go?
imGreek
I've looked in the manual, but cannot find where. It's a KA24DE and I know that one has radiator fluid running through it; the one to the left in the picture I took. Shouldn't that go to the heater core? Where do they go? Thanks!
Modified by imGreek at 7:11 PM 1/16/2010
s13k1d
Car: 1991 240sx
from the looks of it your heater core lines were looped prolly because the core was leaking.
imGreek
Problem is this KA was in a friend's car. The shell has the heater core and everything intact. Should I just run them to there (If I do, which goes on top and which bottom), or loop them together?
s13k1d
Car: 1991 240sx
id try and run them to the heater core if youd like heat. and as for which ones top or bottom im not sure i can check in the daylight tomorrow on my car. but im sure someone on here will know were they go.
1sikS13
Car: 1992 S13 240sx
the one that comes out of the intake manifold goes to the top the one that is on the block goes on the bottom
imGreek
Yeah, that's what I'll probably try; as everything is present under where the glove box is. Thanks.
