Where do I tap into for a fuel rail flush (1991 Q45)?
ti286
Car: 1991 Q45a
I understand that I have to disable the fuel pump (via fuse), then create a loop in the fuel rail and run the car for 15 minutes on the flush fluid. Where do I tap into the rail, and how do I create the loop. I work at a dealership, and will have the help of techs and the necessary flushing equipment.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Infiniti of Beaverton? Eric should be able to help you.
There are several posts on this, best to search on rail flush or posts by Q45tech to get it right (and learn something). Good luck.
ti286
Car: 1991 Q45a
I searched but could not find a DIY for a rail flush. Taking the car to Beaverton Infiniti next Thursday.
DAEDALUS
Car: 1990 Infiniti Q45
The fuel rail has an inlet and an outlet. Doesn't matter which one you plumb into with the flush, but pinch off the other line. This leave the 2 ends that trail back to the tank. If you pull the fuel pump fuse you don't need to loop these, but best to cap or pinch them off to prevent gas leaks while you run the engine.
SFBayQ45
Car: cars
If my dealership does not offer a "fuel rail flush", where else can I go? Are there any national chains that specialize on fuel rail flush (i.e. jiffy lube, sears, etc.)?
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Go to the http://www.bgprod.com site and find a dealer that offers the service.
Don't trust the website, but call to confirm first that the desired service is still offered.
