This is for an SR ECU, but I'm pretty sure that the standard KA is the same!It's number 29 on your ecu!It's the 5th wire in from the left, i believe, a white wire!Before you snip it, use a multi meter and do a resistance check between that wire and the wire connected to the 02 sensor!I'll email you the ecu diagram if you want it!my email is
[email protected]Good Luck!
