where can i get the higher compression pistons for my DE?
uno
i see all kinds for the sohc motor, but none for my dohc motor...I probably just need some direction, where are some places that sell the higher compression pistons for the ka24de ???thanx in advance
Daunttless
Well, you can use the pistons from a SOHC for higher compression, as has been discussed in about 10 threads in this topic.
I also believe that JE manufactures 10.5:1 pistons, you may try them.
I think thats about it for production line pistons, you could always have custom pistons made.
uno
hey thanx for the quick reply... I've read all the 2 million posts about the subject, but i'm still kinda confused...i know the motors are the same displacement so the pistons should work the same, but aren't the heads different? wouldn't i have problem with clearence or do they just interchange?
Daunttless
The fact that the heads are different is why the compression increases, but there aren't any clearance issues. : )
uno
coolso i can buy me 4 pistons from nissan motorsports the 9.?:1 compression ones for the sohc motor and they'll work?sorry bout so many questions just double checking since you are knowledgable on the subject
Daunttless
Theres another post, where Demcj lists the parts numbers for the 8.6:1 pistons, I would use those instead.
Daunttless
http://www.nissaninfiniticlub....=1249
redrocket
Car: 1987 Nissan 200SX SE
2007 Chevy Silverado Classic Crew Cab
1999 Kawasaki ZX9R
If the pistons work can you use anything else from the ka24e on the bottom end of the ka24de like rods, cranks and things like that
Robbie
Daunttless
The rods are the same, not sure about the crank. : )
redrocket
1999 Kawasaki ZX9R
thanks I will try to do some more research and find out if I can
Robbie
TrunkMonkey
Car: 2000 Lincoln Navigator
i'm almost positive that they share the same crank...
but don't qoute me.
grygst76
uno wrote:i see all kinds for the sohc motor, but none for my dohc motor...I probably just need some direction, where are some places that sell the higher compression pistons for the ka24de ???thanx in advance
Want a cheaper way to bump your compression? thinner head gasket!! they do sell them for the KA24DE order it from a nissan dealership or nissmo or enjukuracing you can bump your 9.5 to close to 10 without clearance issues I am going to do that very shortly like by next year--right now I'm saving for the clutch/flywheel combo but guaranteed I'll be doing that next. That is the cheapest and easiest way to bump it.
KwayKer
Car: 1991 Nissan 240SX Coupe
Where can I get the thinner gasket for my engine? (DE)Enjuku only has one for the SR20DET. Also, is this mod perfectly safe, and worth doing?
grygst76
KwayKer wrote:Where can I get the thinner gasket for my engine? (DE)Enjuku only has one for the SR20DET. Also, is this mod perfectly safe, and worth doing?
go to this link
http://www.afsmotorsports.com/links.htm
and look around, you will se a manufacturer that has the thinner gasket. I remember seeing it but not where, good luck
KwayKer
uuugh that list is forever long....guess ill search through it logically.....im sure APC is the one that makes it LOL :)
KwayKer
i didnt find it, if anyone else wants to search that list, and finds it, let me know
grygst76
KwayKer wrote:i didnt find it, if anyone else wants to search that list, and finds it, let me know
I spoke with my buddy Jerry and he tells me to have your head shaved because he can't find a thinner gasket for the KA only sr20
EZcheese15
Car: 2012 Juke SV
2011 Titan Pro-4X
2007 BMW 328i
As far as I know, nobody makes any aftermarket headgasket for the KA, thinner or thicker.
king240
I've said it before, I'll try again, you cannot interchange pistons from the sohc into the dohc, YOU WILL BEND VALVES! valve lift and valve head diameter are too different between the different cylinder head designs.
Daunttless
I haven't heard of anyone bending valves with the dished or the flat top. The only way I could see that happening is with the domed.
ash1y1
Car: Cars, Gadgets & Gizmos, Computers, Health, Travel
Which part number for cams matches my 95 240SE?
12010-30R10 std. grade 112010-30R11 std. grade 212010-30R12 std. grade 3
12010-30R72 oversized 0.50mm12010-30R73 oversized 1.00mm
Daunttless
I don't know which part number it is, but I'm imagine whichever cams are listed for the DOHC would fit your DOHC...?
EZcheese15
Car: 2012 Juke SV
2011 Titan Pro-4X
2007 BMW 328i
ash1y1 wrote:Which part number for cams matches my 95 240SE?
Those look like bearing part numbers, not cam part numbers.
There should only be one part number for cams, and they don't sell them in grades. Unfortunatly, I don't know what the part number is though.
