WHERE CAN I GET SOME FOGS FOR MY 2.5 COUPE
RaiderKID
Car: 2.5 Percision Grey Altima Coupe
OK SO IM ON THE MARKET FOR SOME FOGS DOES ANNYONE HERE KNOW WHERE I CAN GET THE KIT FOR THEM. MY 2.5 DID NOT COME WITH THEM SO I WAS WONDERING IF YOU GUYS CAN HELP?
Blackmobile
Car: 2008 Altima Coupe 2.5S Super Black
http://www.trademotion.com/par...14459
There's a site for fogs, order a left and right assembly from the front lamps category, you'd probably want a stalk (switch) as well so that you can turn these bad boys on. Look under the steering columb, switches category
RaiderKID
steering colum and then what is the next step?
Blackmobile
Steering column, Shroud switches and levers, Combo switch, 2.5S w/auto headlamps.
Chose the 2nd one, w/ fog lamps.
Those 3 things should give you your OEM fog lights package.
RaiderKID
thanks for the info.
Coupeguy23
Car: 2006 G35 coupe sport
Blackmobile wrote:Steering column, Shroud switches and levers, Combo switch, 2.5S w/auto headlamps.
how can you use a steer column switch if your 2.5 is not pre-wired
there asking alot for those fog lights
Blackmobile
Not too sure about that one. I think that if you're not pre-wired you just have to wire them up, run some wire from the proper plug in the fuse box to the lights and get the proper connections/plugs. Someone with some more knowledge can chime in here, i'm just assuming.
And yah those lights are damn pricey, but I don't know of anywhere else that sells OEM fogs. I want to buy those but can't, no shipping to Canada
iiiskylll
How do you figure out if your 2.5 is wiredup or not for fogs?
Coupeguy23
iiiskylll wrote:How do you figure out if your 2.5 is wiredup or not for fogs?
there not pre-wired i wasnt happy when they told me they dont come pre-wired i bought the ones off of ebay those for the the sedans they dont work , so now im waiting to see if anybody will come out with oem part that dont cost so much
