Hey, I've got a couple of suggestions and notes for you:
1st off the SOHC coupler will fit, but not perfect (SOHC throttle body if higher than the DOHC) so it may bend and eventually break as well.
You can use intercooler piping couplers (rubber) but they will not have nipples for your vacuum lines.
If you're crafty, you can use a small piece of intake piping (they sell this stuff at auto parts stores for a couple of bucks) and add your own nipples. This is likely your best option (unless you can find an original one).
How I would do it:
- -Take a piece of the piping (its hard plastic) and tap holes for vacuum plug nipples.
-Moroso makes brass nipples and they are very well milled [part #65390 is a pair that is 3/8" and 1/2"] (just right for this application) and they are also sold in auto parts stores.
-You can use a tiny bit of JB Weld on the threads to make sure they bond to the plastic.
-Use either the OEM coupler ends chopped off, or once again intercooler coupler to secure it to the TB/intake.
-If you want it to be really clean, coat the piping with rubber truck liner!
Hope I could help, good luck!
