Where can I get my Infiniti M56 supercharged?
Mayo313
Car: Infiniti M37s
Infiniti M56s
:gotme I really want to install a supercharger kit but I don’t know where and if that is even possible.. I have not seen anything online about and m56 supercharged ..
Ilya
You may need to contact one of these vendors and get it custom made:
https://www.google.com/search?q=vk56vd+ ... e&ie=UTF-8
PalmerWMD
Car: 2004 350Z
LIke ILya said.. any of thos kits could be made to work.
Any large and respected tuner should should;d be able to do it.
AAM competition in MD does one off with their own adaptors at times.
I would also consider a turbo kit.
Since a turnkey solution does not exist it will not be cheap.
However an alternative might be to do some bolt ons and then get an osiris uprev tune.
A lot less money and should still yield a noticable improvement.
Mayo313
Car: Infiniti M37s
Infiniti M56s
Ilya wrote:
Mon Sep 28, 2020 8:36 am
Okay I will check them out thanks
Mayo313
Car: Infiniti M37s
Infiniti M56s
PalmerWMD wrote:
Mon Sep 28, 2020 11:55 am
I will look into this as well .. I appreciate it
PalmerWMD
Car: 2004 350Z
I guarntee AAM competion can do it as a one-off.
https://aamcompetition.com/
If you are lucky they have a used twin turbo kit on the shelf.
Their fuel soltuions are usually in stock and will fit any vehicle so no special adaption needed.
Same with their tuning software, which will work just fine with your car.
Still it wont be cheap.. due to having to create and/or bend the hardware for the TT kit.
If you tell us which state you are in we might be able to direct you to a competent known Nissan/Infiniti tuner in your area for either forced induction or a milder setup.
Or as mentioned elsewhere australian kits for the 5.6L exist hich are said to work quite well.
Here is one in an Armada/Patrol ( same engine as yours)
https://www.youtube.com/watch?v=onMVEcuJLOs
PalmerWMD
Car: 2004 350Z
Also check out this thread:
topic627637.html
ken in az
Car: 2011 Infiniti M56
2002 Chevy Silverado
1989 Nissan 300ZX
2008 Ford F250 Diesel/Canam X3 Turbo
https://harrop-usa.com/nissan-titan-230 ... arger-kit/
Harrop is an Australian company making a footprint in the States. They are very well known for their engineering of intake manifolds.
I may be buying their kit to run on my car even though it's for the Titan, it's the same engine in the M56/Q70.
reggiebrown40
Car: 2018 Infiniti Q60 Red Sport
2011 Infiniti M56x - Dead
PalmerWMD wrote:
Wed Sep 30, 2020 1:18 pm
I guarantee AAM competition can do it as a one-off.
Their fuel solutions are usually in stock and will fit any vehicle so no special adaption needed.
Or as mentioned elsewhere Australian kits for the 5.6L exist which are said to work quite well.
Getting my EcuTek and tuning done by AAM for my Q60 red sport. They were highly recommended.
