s14det wrote:NISMO_RB25
I tried to PM you put I am not able to, I just had a couple of question for you about your RB25 that you got from
http://www.dragdriftautox.com. Since you did not get the front clip and only the engine and stuff, was wondering if the install went fine without getting the whole clip. Also how was your engine that you got from them, was it in good shape inside and out? I am thinking in getting the engine set + the factory IC like you did for $2700. Thanks for any input that you can about your swap and your purchase from
http://www.dragdriftautox.com. I will be purchasing a rb25 in a few weeks or so and am figuring out which place to order from.
Please guys, give some input
The install went fine. I used mckinney mounts and driveshaft, so that uses the KA xmemeber. I did it by myself with and engine hoist and jackstands in one day. Routing the intercooler and piping was a pain and took most of an additional day.
Condition of motor= excellent. hadn't been washed, which I liked, because I could see if anything was leaking. started first crank, and I have been driving it to work and it runs great.
The only thing that was messed up, was the oil dipstick got broken in shipping. (I just flattened my KA stick and scored new marks to match the RB, so I could check my oil. Ghetto but, I spent hours at a junkyard trying to find one that matched the RB, and no luck)
Overall, I agree with most people here. I had a good experience and Louis answered all my emails and questions and called me. Sent pictures before it shipped, and it arrived when it was supposed to.
If you go with a motor set you will need to use a mounting kit, which I would recommend doing anyway.
