Fenvy »
https://forums.nicoclub.com/fenvy-u13048.html
Fri Oct 15, 2004 6:45 pm
pgbrian,
phase2 does not have defi din gauges
bad mojo,
all eletronical gauges have sensor/sender that remains in the engine bay and a thin wire runs back to the gauge, same with the defi din gauge.
defi din gauges are nice, but spl sells it for 530$ last time I checked. the best price I seen is 470$...
I may be able to find it cheaper or the same price again, if I do I'll let you know.
I been wanting to get the egt but I heard they are too slow to respond to rich/lean situation
and xs-engineering confirmed it:Quote »Q: CAN I USE AN EGT METER TO DETERMINE IF I樽 RUNNING RICH OR LEAN?A: Although an EGT’s reading may give you an indication of richness or leanness, it is, by nature, a slow-responding device and should not be used as the main air/fuel ratio-metering device. Accurate air/fuel ratio monitoring devices that are reliable start from $1200.00 on up. Any other air/fuel ratio meter should NOT be relied upon. [/quote]
