boostedh23a1https://forums.nicoclub.com/memberlist.php?mode=viewprofile&u=113&sid=f5569928cce91141240d72b396905063Where can i find this water fitting.Wed Oct 10, 2012 4:22 am
Postby
Darius »
https://forums.nicoclub.com/darius-u5470.htmlWed Oct 10, 2012 10:22 am
I was going to say it looks like a freeze plug, but I think that's where the intake manifold coolant line fitting goes. It should be a steel press-in fitting similar to the valve cover PCV fittings.
Postby
SullivanRacing06 »
https://forums.nicoclub.com/sullivanracing06-u63212.htmlThu Oct 11, 2012 7:36 am
drill and a tap. id leave the heater core hose hooked up even if your deleting your heater core, have that hose running to the back of the block to keep coolant flowing to the cumber 6 cyl
