where can i find straight cut gear set for a r32 rb25det transmission
SullivanRacing06
Car: r32 gtst, 06 350z, r32 gtr, rs4 steaga, 04 350z, f350/6bt
my 25 trannys about to go out on me, anyone know of where i could find a srtaight cut gear set for a rb25det transmission? anyone used or installed straight cut in a 25 transmission yet? info would be greatly appt!!
StricNyne
i kno there is a ati powerglide adapter, and as far as trans go, i have only seen aftermarket rb26 trans, not saying 25 dont exist just havent seen them, maybe osgiken makes a gear set you could use
Joe
SullivanRacing06 wrote:my 25 trannys about to go out on me, anyone know of where i could find a srtaight cut gear set for a rb25det transmission? anyone used or installed straight cut in a 25 transmission yet? info would be greatly appt!!
do you have any idea how loud straight cut gears are?
and is there any reason you want them? is this a race car?
StricNyne
hmm Dsport did an awesome write up on trans comparing staight cut, slant cut, dog boxxes and yadda, but man the stuff was super expensive i think sourcing another rb25 trans or rebuild the one you have now, or even talk to the guy who is making z33 trans adapter would be cheaper, and i didnt even think of the noise factor heh
here is os giken stuff
http://www.osgiken.co.uk/
here is ati
http://www.atiperformanceprodu...t.htm
i think that h pattern is only ay to do a street car
SullivanRacing06
im not worried about noise, im about to do the injector swap, making more power already runied my 25 transmission, and im deciding that i dont wannna pay for the next one and next one, just do the str8 cuts n get it over with
wawazat8402
Car: 89 Sil80- RB25DET
do a built T56 swap, it will be cheaper.
REDLN
Car: 95 Nissan 240SX SE
here is a place that has them know for sure they have em for the 26. but very $$$$.
http://www.hioctaneracing.com.au
l0nestar
Car: 1993 Nissan 250SX
2004 Toyota Altezza
1963 Chevy Impala SS
REDLN wrote:here is a place that has them know for sure they have em for the 26. but very $$$$.
No kidding ~ $9,000.00 AUD!
REDLN
yeah so maybe the gm adapter plate and a t56 (if it will work don't see why not) might be the best way to go unless you can find someone in japan that can find a you a dog box for cheap. gl on that too.
Largekid
Car: '96 RB S14 SE, '04 LS6 CTS-V
i've been kinda tossing the idea around of rebuilding my RB25 transmission as well...has anyone ran a T56 on these motors? How far back does it extend the shifter location? I know as far as building up a 25 transmission...the internals are the same as a Z32 NA...but finding built internals for it has been kinda hard so far. I'll start really looking tnto it when my transmission goes pop though...lol
StricNyne
rbtally ran one i believe he is rarely on though, maybe one of the datsun guys did it
gawdzilla
Car: none
subaru guys run PPG alot... they make nissan stuff too... http://www.ppgearbox.com.au/index-html.htm
theres a few PPG dealers in the US
the stock trans will last if you're not smashing every gear trying to be the next john force on the strip. if you are, just get an auto
Largekid
gawdzilla wrote:subaru guys run PPG alot... they make nissan stuff too... http://www.ppgearbox.com.au/index-html.htm
lol! I'll make my way on the strip a few times for sure...but my car is a street car. Unfortnuatly, my TQ should outweigh the TQ rating of these trannys...so its a grenade under my hand until I get it built properly. Who wants a boring auto when you can have a fun manual?
gawdzilla
Car: none
Largekid wrote:Unfortnuatly, my TQ should outweigh the TQ rating of these trannys...so its a grenade under my hand until I get it built properly.
please tell me how you calculated the TQ rating of your transmission... i'm curious
autocrossing
Car: R33
I have the OS Giken 1-5 gear set in my RB25 trans, the gearing is nice, but the peace of mind is the really nice part. To be honest though, I'm getting to the point where I wish I'd just done a TH400.
Largekid
gawdzilla wrote:please tell me how you calculated the TQ rating of your transmission... i'm curious
this one time on the internet
no, I've just read that these trannys dont like torque above like 500ft lbs, specifically the 3/4 gear shift forks...so I would just like to make sure i'm not going to blow it up
JPsNissans
Car: 04' SE-R Spec V, 95' S14 240sx
autocrossing wrote:I have the OS Giken 1-5 gear set in my RB25 trans, the gearing is nice, but the peace of mind is the really nice part. To be honest though, I'm getting to the point where I wish I'd just done a TH400.
Where did you purchase it from and for about how much if you dont mind me asking?
neonbomb
So who's the guy making the z33 bell housing adapter and when will it be done??
StricNyne
redln33 or some**** its not ez u need to macing iek inch off og z33 housing but said shifter was in stock location
autocrossing
Car: R33
neonbomb wrote:So who's the guy making the z33 bell housing adapter and when will it be done??
I know Nick at Omega-Motive was working on a Z33 adapter, but it's been placed on the back burner until work slows down.
JPsNissans wrote:Where did you purchase it from and for about how much if you dont mind me asking?
I bought the trans/gearset used from a local guy, as I recall the gearset was purchased through otomoto in aus.
240z4u
Car: '95 Nissan 240SX
StricNyne wrote:redln33 or some**** its not ez u need to macing iek inch off og z33 housing but said shifter was in stock location
WTF, I can barely make this out so let me translate.
Redln33 or some #$%^, its not easy, you need to machine like an inch off of the z33 housing but he said the shifter was in the stock location.
SullivanRacing06
so anyone have info on me being able to buy internals to handle a hg hp engine
StricNyne
yeah, i type like **** some times, the guys name is redlnn33 or something similar to that, his post is in fabriactors market i think, than i meant to say usiing the adapter isnt easy, you need to machine an inch off the z33 bellhousing to use it
