benemorius »
https://forums.nicoclub.com/benemorius-u17066.html
Fri Aug 04, 2006 12:46 pm
More misinformation. Here I come again.
The vent outlet temperature and system pressures are directly dependant on several things. One cannot declare them out of spec without knowing the ambient temperature and relative humidity. You will find a graph in the FSM which will help you determine what your pressures and outlet temp should be for a given ambient temp and humidity, but I can tell you right now that 40 psi and 60-70 degrees would not be out of the question on a hot day.
Freeze-12 does not contain propane or any other hydrocarbon. Most blends which do contain a hydrocarbon contain butane or isobutane. The amount which they contain is not enough to be an explosion hazard. (most are between 1% and 4%) Of course, we are talking about the EPA-approved replacements here.
Hydrocarbons actually make splendid refrigerants. Many, including myself, are not certain that they pose a risk substantially greater than any other refrigerant. If you are interested, check out HC-12. It cools better and is cheaper than R-12, though is not EPA-approved for motor vehicle use.
I do not recommend the use of Freeze-12 for two main reasons. Firstly, it is a blend and as a general rule I do not recommend blends. Blends are subject to something called fractioning, whereby the blend ratio is altered over time due to the constituants having different rates of absorption/leaking. This can alter performance and much more importantly it makes recovery questionable. Now, many argue that this effect is minimal and I actually don't disagree, but the last thing we need is one more source of refrigerant contamination. The second and much bigger reason is that Freeze-12 contains an HCFC, which DOES deplete the ozone layer. The whole reason we are moving away from R-12 (a CFC) is ozone depletion, so why move to another ozone-depleter? The HCFC contained in Freeze-12 is scheduled to be done away with in the next couple of decades, as I recall, but why wait? It is true that Freeze-12 cools better than R-134a and you are free to make your own decision, but I have given you my reasons for not using it. If you must use a replacement, I would recommend R-134a (because it is pure and ozone-friendly) or HC-12 (because it is dirt cheap, cools VERY well, and completely environmentally safe)
