I don't get the interior paint thing at all.Q451990 wrote:Interior parts are not painted, they are typically made out of the color of plastic that they meant to be. I think your best solution is to just use the black ones...
Heath
Even with this kind of prep there is no way to get paint to last on something that you touch regularly-literally no way.anlasak wrote:You will need to: -sand(fine grit) -prime -sand(fine grit)- paint-wet sand(fine grit)-dry-paint-clear coat
Choose you materials wisely, take your time, and it will come out just the way you want it to.
Then its time to get out the plaster-of-paris and start making some phone calls to industry plastic chemical suppliers for some raw materials.bullittandy wrote:
