dickie »
https://forums.nicoclub.com/dickie-u32299.html
Fri Aug 17, 2007 10:16 am
i dont know much about sr motors, so i moved this to the rwd sr section for you. there are key differences between the models and motors you should be aware of when swapping.
mechanically, everything should bolt up. if you can find someone to convert the wiring harness for you, you should be good to go.
i would assume if you can't find an install dvd that they are either really hard to come by or they dont exist. maybe ask around this section though, i KNOW there are a ton of people more knowledgeable than me to help you out.
