Where can I find a low milage KADE?
SilGuy
Where can I find a low milage KA24DE. My existing engine is eating oil and at times, you can smell the oil in the car and its annoying. Dunno what it is, but I'm tryin to search and find out. So far, from what I've gathered, it could be the oil rings, pcv, and valve seals. I don't get burnt off some idling, so i dunno if its the valve seals. Only time when I can see the blue smoke from my exhaust is from riding on the clutch from 1st after a stop. Anyways...I want to rebuild my engine, but don't have time, so I will need something running then rebuilding the engine on the side. Anyone know where I can get a lower milage KA or perhaps a jdm KA where I can jus swap in and run reilably for awhile until my engine is rebuilt. Thanx...
90SXSE KA24ET DREAMS
Car: 1990 Nissan 240SX SE 5spd KA24E-T project
i found this... I don't know if you saw it or not.. but here's a link for a ka24de that has 80,000 milage.
zerothread?id=136946
also check this one out too
zerothread?id=136423
gomer23
Car: 1989 Nissan 240sx
edited.....didnt see you wanted a DE my bad
SilGuy
thanx for the posts. Damn..just when I moved to the coast people want local pick up in the midwest..damn it. I might buy it and drive back to swap my motor though. I will contact those people. Also..any of you have any opinions on the oil consumption problem? thanx....
SilGuy wrote:thanx for the posts. Damn..just when I moved to the coast people want local pick up in the midwest..damn it. I might buy it and drive back to swap my motor though. I will contact those people. Also..any of you have any opinions on the oil consumption problem? thanx....
no problem, and as for the motor you have now... I'd say repleace the head gasket, get a new timing chain kit and replace all that stuff that includes timing, and the oil pump, repleace the valve seals, and valve cover gasket, and spark plug seals and after all said and done finish it up with a full tune-up, cap,rotor,plugs,wires.
sounds like a lot of money and work but really its not all that bad and if can't find a better motor then i would say fix yours and replace everything i listed above.
