Where can I find a list of possible reasons my "check engine" light is on?
rich 96Q45 san diego
Car: infiniti Q45 '96 83,000 miles, properly service first 75k
I went out of town for two months. When I started my 96 Q45 it started after cranking it about ten times for about five seconds each time. HOWEVER, the CHECK ENGINE light came on.What are the possible reasons it would light up? The light is still lit after a fresh tank of gas. I was thinking maybe oxygen sensor?Anybody know a link that shows what it could be?
THANKS!
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
All of the codes that can trigger the CEL are listed in the FSM.
What does the OBD II scanner reveal? Because of the difficulty starting, you may well have more than one problem.
With no stated maintenance history, we cannot offer anything more than WAG.
Thanks for the reply.
Do I need any special tools to find out what the code is?
Q45tech
All 1996 and newer cars use OBDII and thus require a code scanner tool..........don't cheap out on one that just reads and won't reset codes.http://www.harborfreight.com/c...98614
jimbyjimb
Car: 1992 Infiniti Q45
CAS, fuel system, ignition system. Use the KISS principal.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Your best bet might be
http://www.jerrytucker.net
before you do any more expensive damage. They can at least give you a heads up what your car needs.
jerrytucker retired and sold business to Brian who used to work for Jerry. Brian was not there, but a miguel helped me out. thanks
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Great! What was (were) the solution(s)?
Brian's place charges $50 to find out what the check engine light is on for, but its returned if you do any work there. Miguel checked out the front suspension and I need everything and they came up with a price of over $1800. I asked about aftermarket parts. Brian was not there that day and he was supposed to call me after the weekend about aftermarket. I took the advice of this forum and put tokico blues a few weeks later and saved some dough - ok, a lot of dough. The check engine light was going off for two things related to knocking. Miguel said to see if they go off again before doing anything. The light has stayed off. I think the sensor went off because of the car sitting for so long. I put the $50 toward the place putting in the darlington piece for the blower. Its nice to have the blower working.
Now i am back here to learn more about the speed sensor. I am writing a new post next.
Thanks all!
