Where can I find a detailed video of removing the valve body?
727G35
Car: 03 Infiniti G35 sedan
The ones I find there not too specific of what bolts and why. If you have one out there hidden, please let me know.
P1992
Reason: TYPO
What are you removing? Throttle body? Valve covers? Or are you talking about the automatic transmission valve body?
727G35
Yes I was talking about the automatic transmission valve body
Ah, sorry.
I'm not sure if there's a video anywhere, but here's the FSM for the 03 G sedan auto trans: https://www.nicoclub.com/FSM/G35/Sedan/2003/at.pdf
727G35
Thank you you seem to have all my answers lol
727G35
So I found a video on youtube
https://youtu.be/8vix6lxXfXY
But this guy has the transmission removed to access a clip on the top.. does that mean I have to drop the transmission??
Is there any other way to fix this 1772 it's such a freaking hassle
727G35
I need someone that's done it before so I know if u can just unbolt everything or what?
I know some you dont because coolant flows thru it, but how can i know what to lower and when?
Anyone with experience please post or email me with the subject valvebody ([email protected])
The valvebody can be removed without removing the trans.
I'm assuming the clip is for a wiring harness, but I wouldn't sweat that right now.
I'm not sure I understand your last post: "I know some you dont because coolant flows thru it" ???
Coolant doesn't flow thru the trans - the ATF flows thru the radiator, though. You shouldn't need to disconnect any of those lines, since the VB is inside the pan.
Gonna be honest here, I don't know your level of expertise, but swapping a VB on a modern auto trans isn't a cakewalk. Hate to see you get it gutted and then be stuck.
