Where can I buy the discharge gasket for a T3/T4?!
kevdog240
I need to get it NOWISH. i tried to play with those cheap gaskets from advanced auto and it burned up just as everyone said. ok, im an idiot with a big exhaust leak in my 240... where can i get the inlet and outlet gaskets for my t3/t4? (the 5 holed outlet)
thanks guys
DRIFTEADOR
you dont need them unless your flange is warped, in which case have it re-machined. gaskets suck
klattr1
Car: GT42R powered S14/KA
people dont usually use outlet (5 bolt gaskets) like wtb240 said.
i got my 4 bolt t3/t4 inlet gasket from Precision Turbo. It was like $5 before shipping.http://www.precisionturbo.net
toki
or run down to a ford dealership if you need one like yesterday.
MaxType 240
Car: 1995 S14
toki wrote:or run down to a ford dealership if you need one like yesterday.
The gasket for the manifold is easy to find. Does a 5-bolt gasket even exist? I called Ford muscle shops and they said they simply don't use gasket or use the high-temp copper stuff. Personally, I keep breaking the damn bolts, backing out, tapping, helicoil, then putting new ones in. One of these days, I'll get some good studs...
