teddy »
https://forums.nicoclub.com/teddy-u22985.html
Thu Apr 06, 2006 4:27 am
Morph is correct. You can rebuild a ball bearing turbo, but not in a standard journal bearing t3/t25 kind of way. In order to rebuild the ball bearing, you have to replace the whole center cartridge due to the bearings being pressed in. The center cartridge is essentially everything inside the turbo, except for the housings. The cartridge will cost you almost as much as a new turbo.
