So then what the heck is that wire bolted down by that slotted screw? I know it's hard to see in the pic, but the wire has a little orange rubber or plastic sleeve then the wire is black and goes into another bundle of wires. I went to the Nissan dealership today and ordered what should be the wire to ground the alternator. Is the alternator ground going to be a steel braided strap like some other grounds are? If that is the case then should i just disconnect whatever is already on the slotted screw and attach the strap I get from the dealership? Thanks again everyone for your information and advice. O btw I have gotten tested and everything checked out, but i might get that rechecked because I'm a little doubtful of the competency of the guy who did it.12Ounce wrote:/
BTW, I do not see the ground wire in the photo... is it up inside the harness cover somewhere?
