Holvinator »
https://forums.nicoclub.com/holvinator-u138020.html
Tue Aug 09, 2011 8:55 am
Ight to make it easy for you guys this is the adapter you need so you dont have to brake your old b.m.c just to get fitting (use your old b.m.c as a core so u can save some $$$ make sure to remove reservoir and I believe the 2 rubber washers or plugs whatever they are lol were the reservoir hooks up into b.m.c. Unless u wanna buy whole kit and spend about $85 extra) Havent install b.m.c yet but once I do it Ima come back here and let yall know if it worked fine which I don't c why not.
I ended up buying 2 adapters cuz the vendor of this hydraulic shop didn't have or sell that specific adapter with the specific thread needed. Here's the print out on my receipt...
Thread Adapter: 10 X 1MM - 3/8 X 24NF
Thread Adapter: 3/8 X 24NF - 10 X 1
H/D Copper Washer Pack 10MM ID
*** I think brake line screws into the 10 x 1MM.
So pretty much if u can find an adapter that its 10 x 1MM - 10 x 1MM you'll be set. No need to use 2 adapters just to go metric. Im sure they sell them. They need to see b.m.c so they can get u the right adapters tho. If I remember Ima take pics of them and post them here after I get off work so u can see how adapter looks from both ends.
CORRECT ME IF I'M WRONG!
*** If you live in Kissimmee/ F.L contact Tubes N' Hoses of Osceola @ 407-933-8502 & talk to Shawn. That's were I got my adapters. If not just go to a Hydraulic shop and bring your b.m.c I'm sure they'll have the adapter you need, or at least they could get it next day or same day for you.
