TachyonS14 »
https://forums.nicoclub.com/tachyons14-u10260.html
Sun Jan 25, 2004 4:09 pm
Ok, I have a 97 240sx and since I've had It, It's always had a vibration problem. The vibration Is engine related and causes vibration throughout my dash and my steering wheel. It seems to really vibrate around 2krpms. So, I've gotten new spark plugs, plug wires, O2 sensor, cap and rotor, air filter, fuel filter, cleaned the throttle plate (which was very dirty btw) all new motor mounts (left, right, and transmission), I also ran Seafoam through the gas tank, crank case, and brake booster line and yet my problem remains!
The only person I've seen on here with the same type of problem is S14Life In this thread http://www.nissaninfiniticlub....48430
Ok, so today I busted out my Chiltons and It said rough Idle and virbrations could be caused by 1) Clogged air filter 2) Dirty/Bad Gas or 3) Bad fuel pump. I think I've narrowed my problem down to fuel since I've done everything with the ignition/spark. Now, do you guys think that replacing my fuel pump or injectors might fix the problem? I feel that maybe one injector is bad and not spraying enough fuel which causes the other injectors to go out of wack and making my engine not run like it should. Or, my fuel pump is bad and Is not pumping enough fuel to my injectors? What do you guys think?
