NJGuy »
https://forums.nicoclub.com/njguy-u191160.html
Tue Apr 22, 2014 11:23 am
As you know, there are many different thoughts on fluid change intervals for a differential. Some say to do it 'early' to get rid of all the break-in material. Infiniti isn't very clear as far as set intervals, but according to what they've published, the differential fluid (and others) do not necessarily 'require' replacement. My opinion falls somewhere in the middle of these two philosophies. I'd say just change the fluids at whatever interval you're comfortable with. And other than the ATF and transfer case fluid (which I've already questioned), the fluids for the AWD system aren't anything special. So you're not bound to the Infiniti dealer for those fluid change services.
The 2011 EX has the 7-speed auto, correct? I don't believe that this transmission designed to be 'serviceable' and is supposedly sealed. It might be possible to change the fluid in the 7-speed, but I personally haven't seen any procedures yet that show how.
By the way, I don't think you can compare the MDX rear differential to the that of the EX. The EX is RWD based and uses a conventional differential design. I'm not intimately familiar with all of the technical details, but I think the EX uses Nissan's ATTESA system for controlling power distribution to the wheels.
The MDX, on the other hand, is FWD based has a much different rear differential. I don't know which system your MDX used (VTM-4 for first Gen, SH-AWD for second/third Gen), but I believe those systems use some type of electronically controlled wet clutch to distribute power to the rear wheels depending on the conditions.
So essentially comparing the differentials of the MDX and EX is like how the saying goes, "comparing apples to oranges".
