When to change stock struts?
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
aricbeemer
Our Versa only has 31,000 on it but I didn't see strut changes in the maintenance manual. I hope they last awhile.
Promise Land
Car: 2011 Nissan Versa
2001 Chevy Suburban
1992 Ford Mustang
Usual changing point is when the seals fail and they leak oil. They should last a good while.
aricbeemer
Promise Land wrote:Usual changing point is when the seals fail and they leak oil. They should last a good while.
That's good I know the Versa seems to have pretty good stock struts.
br4dysays
Car: 06 Nissan Altima SE-R
i put on kyb's all the way around when i did tanabes, just cuz. had about 55k, they seemed fine.
Shad0wXCalibur
Car: Nissan Versa SL Sedan
Besides the obvious leaking fluid, you can push down on the car to see if the shocks have gone bad. If it bounces before returning to position rather than firmly returning back to position, they have gone bad. The car will also feel really floaty like a Cadillac or something and bottom out more easily on big bumps.
Return to “Versa Technical Discussions”
