Drivers side which can be reached with 02 socket and two long extensions from the top of the motor where the 02 sensor harness is located by the EGR also! Pre-spray with PB or other rust sprays and unplug harness first because it will wrap around extensions while turning so follow the rotation of the socket and extension with the 02 wire!Louis Cyphier wrote:Drivers Side or Passenger. Threw a P0138 and P0139 and am replacing the rear heated O2 on the Left Bank, but im not 100% which one its refering to.
As long as you are not in a drive on the left-hand side of the road country!Q451990 wrote:The side they're referring to is related to the driver's position when sitting in the car. So as you're driving... the left side of the car is the driver's side.
Actually I guess that explains why they use "Left" and "Right" instead of "driver's side" and "Passenger's Side" when writing the manuals! Never thought of it before. That way, no matter what side of the car you're sitting in (as long as you're facing forward) - the left side is still left, and the right side is still right.szhosain wrote:
In the U.K. (among other places), you sit on the right side seat and drive on the left side of the road.
Z
doh! didnt think about that one.maxnix wrote:The cylinder numbering starts with the left side which is all odd.
