seang »
https://forums.nicoclub.com/seang-u122444.html
Tue Oct 20, 2009 4:11 pm
Yep, my buddy had a cat go bad and it would run fine for a little bit, and then it would just choke the engine right down, sometimes stalling it out. Weird stuff. You should unbolt the cat, and test drive it for a while. It will be loud as hell, but at least you would know for sure. the bolts are probably rusted solid, so you might have to cut them off and replace them if the cat is still good. Or you could just be naughty and leave it off or hollow/through pipe it.
It's a better bet than replacing an already good MAF sensor and still having the problem.
