when is replacing the fpr required?
deezlins
Car: 95 240SX SE
When is replacing the stock fpr required?
huguetpj
Car: 93 KAT Coupe
When it is busted
:: orion ::
Car: '96 240SX, with KA-T @ 12psi...
If you're fuel pressure is out of spec:
~34psi with the vacuum line connected, ~43psi without...at idle.
- Brian
huguetpj
Car: 93 KAT Coupe
:: orion :: wrote:If you're fuel pressure is out of spec:
- Brian
Much more concise/helpful reponse than mine, Brian :pface
deezlins
Car: 95 240SX SE
do you need a different fpr with higher boost? or will stock be ok as long as it is in good shape?
:: orion ::
Stock is fine..does well at 12-13psi on my KA-T, and I have seen setups do +400rwhp with OEM regulators.
- Brian
