thanks i will do just that and use a small beed and give it proper time to dry a leakis better than no gasket at all i think. how can i set the aac to the correct timig for more low end torqueor hp?anlasak wrote:You can use RTV but you do so at your own risk.
Too much and you could end up plugging the holes or worse yet, having pieces(sp?) of RTV get down into the valvetrain/cylinder.
Too thin and you run the risk of leaks.
The IAC only controls idle. hence idle air control valveejXa q45 wrote: thanks i will do just that and use a small beed and give it proper time to dry a leakis better than no gasket at all i think. how can i set the aac to the correct timig for more low end torqueor hp?
to late for that !!!!!!!! i just did it and i all ready was driving it with a gasket for weeks. why do you think this is a bad idea?elwesso wrote:dont use RTV!
Id rather see you wait and get one from Joe and just put it back on with no gasket......
part number 23785-60U01
well don't i feel dumb. how do i set this to the perfect settingelwesso wrote:
that is true i will take my chances ,maybei will buy a new unit when the time comeelwesso wrote:I just dont like the idea of RTV in that area... Its gonna be a ***** to clean up when you do put a gasket on.
