nyc240sx wrote:I have my timing belt set correctly all the dots i have were lined up with the dots on the cover and the oil pump...I know theres multiple lines on the crank pulley thats what i was talking about mine is set on the yellow/orange mark which is 0* its the first mark from the right... Is that where its supposed to be?
Dude, it isn't us that isn't answering your question, it is your misinterpretation of the FSM and our responses.
First, before anything else, you say you lined all the gears up with the marks and installed the belt. I say screw the marks because they aren't exact. Especially the oil pump notch. You could easily install it one tooth off. You have to go by the marks on the timing belt matching the dots on the cam gears and crank timing gear. If you did that and are 100% sure of it, then continue to the next comment. If not, or you are questioning yourself, verify it before putting it back together. Count the teeth in the belt between the exhaust cam gear dot and the dot on the crank timing gear. Should be 47. See page EN-56.
Okay, the FSM is not telling you that you need your crank pulley to be at 15*BTDC upon installation. What you are reading into is the ignition timing setting for base timing when the engine has warmed up. rb25det250sx is right. Once you have verified the timing belt is installed at the correct position, button everything up and reinstall the CAS in the center of the slots. Get a timing light and check the timing. If after the engine warms up, it is not at 15*BTDC, slightly rotate the CAS until the third white bar lines up with the bump on the lower timing cover. Tighten the CAS down and off you go.
Get back to this if you have any further questions.
